removing a zt-5400 is3200z hydraulic drive
bones1
Has anyone removed a hydraulic unit on one of these IS3200Z Ferris machines, I have one leaking oil badly and would like some information on the steps to do this.
Generic information
1) jack up back at lest 12" and support on strong jack stands
2) remove the drive belt by pulling against the idler tension spring, I think that ferris out a 1/2" hole for a breaker bar
3) remove the wheel\
4) remove the support bars between the 2 drives
5) remove the control rods at the transmission
6) put a jack under the hydro to take the weight ff it
7) remove the 4 bolts holding it to the frame
8) slide it down & inwards to remove from engine
9) curse yourself because you dod not go to the Ferris site & download the parts diagram & now found there was only 2 pins needed to remove the controls
10) Panic because you did not take photos and have no idea about how it goes back together
bones1
Well, we are getting somewhere
