OK, I gotta ask. What exactly does this do?
Wanted to share the "striping kit" I built for my 54 Raptor SD. Relatively easy to build with some simple materials, instructions and detailed parts lists at lawnsite.com:
That looks very nice!!! Question...it doesn't appear to have any way to disengage the roller, so you are kinda locked into a "full-time" striping system....right? My OEM Gravely Hex Roller Striper can be raised up and locks into the handles used for raising it by pivoting clasps. Therefore you can "turn it on" and "turn it off". Of course, many other striping kits(such as the rubber flap deck systems) are also "full-time" and cannot be "turned off". That does indeed look, though, as if it will stripe nicely!!!! Post some pictures of your lawn after using it(we wanna see the stripes:0)
Sure thing. I'm going to add an eye hook and a quick-disconnect to clip it to the trailer hole on the back of the mower once I get a chance. Can't disengage it from the driver's seat, but I can do it manually when I don't want to use it. The hitch clips and clevis pins also allow for me to easily disconnect it overall.
