push button switch part# 781211 and LS Brake Bell Crank part # 116142 adjustment
fan45acp
  • / push button switch part# 781211 and LS Brake Bell Crank part # 116142 adjustment
This adjustment is on a Hustler RSD. When the mower is in park, the LS bell crank does not engage the push button switch far enough to let the mower start. I have a small piece of hard rubber attached to the bell crank lever that engages the push button switch part so the mower will start. Question I have is how do I adjust this so it will start.:cool:
http://i97
[URL=http://s979.photobucket.com/user/fan45acp/media/IMG_0500.jpg.html][IMG]http://i979.photobucket.com/albums/ae276/fan45acp/IMG_0500.jpg
Bottom picture is the right side. It's adjusted correctly.
fan45acp
Problem solved. Loosened the two bolts holding push button switch and slid switch forward. Simple..:laughing:
