fan45acp
- Feb 24, 2015
- 3
- 14
The new mower has 3.6 hours and the pump drive belt broke today. I loaded the mower up and took it to my dealer. The mechanic said he has fixed 5 Raptor SD with this problem. He said he would remove the hydros place a washer (spacer) on each side because the belt is interfering with the cooling fan on the hydro. When this happened it sounded like an idle pulley was making noise and had vibration. The belt broke right away. I sure hope it gets fixed quickly and I have no more problems. This is the second time that I have cut grass with the mower and it really cuts grass Very Well.
