ChairChris
- Oct 23, 2013
- 1
- 2
Hi folks,
New member here. I own a ten-year-old Husqvarna YTH1542XP with a 15hp Kawasaki V-twin. Last week the PTO clutch frooze, causing the engine to stall. The fuse also blow, maybe when the clutch frooze or maybe when I tried to re-start the engine. I have installed a new clutch, but I'm having trouble getting power to it. I can confirm that the clutch works and the electrical connection to the clutch is good. I can get power to the clutch if I by-pass the switch (red wire) and the relay (black wire). My guess is that I fried something else electrical. I think it might be the relay, which also connects to the switch, but I don't know how to test the relay.
If anyone can help, I'd be most appreciative.
Many thanks,
Chris
Many thanks,
Chris
