Hi everybody,
first of all, sorry if I misuse any words here - I am no engine specialist and don't always know the specific english words.
My mower has a Briggs&Stratton 650 Quantum motor (190cc), Engine model 124T 02 6567 H1 (2011 model).
Problem is that the engine started stuttering and shut down as soon as the mower got hold of some lawn. I switched the spark plug and also the ignition coil which solved part of the problem.
But the engine still wouldn't run smoothly. Therefore I checked the throttle and the carburater. I found that there's a problem with the connection between the plastic arm that controls the butterfly valve and the metal arm that reaches out from underneath (see photos). I tried re-aligning these and got them to work again, so the engine would run much smoother and won't shut down anymore.
But I am not sure which is the correct way these two parts have to be aligned to each other. Maybe one of you has a drawing or a photo of how they are supposed to look.
Thanks and greetings from Germany
Rick
Rick
