PTmowerMech
- Apr 16, 2018
- 396
- 3,019
I replaced the on/off switch, but when I put everything back together, the cable hangs up on something, when the cable is connected to the throttle plate. Remove it from the throttle plate, and It's free as a bird. With the cable disconnected form the throttle plate, it's springs back as it should.
It feels like the trigger itself is rubbing on something, even when the mounting screws are loose.
Anyone know what could be going on?
