abarone300
- May 8, 2018
- 11
- 34
Hello everyone
I own an HT-R3009, and when the cutting blade is engaged I loose more power than normal, in fact if I go over tall grass the engine will stall. When cutting blade is disengaged the engine runs fine for the exception of misfiring sometime. I cleaned the spark plug, no change. Do you have any suggestions? Thanks
