popping noise from under flywheel
stevo123
My 22 hp B & S engine makes a loud popping noise when you fire it up. sounds like coming from under flywheel, no power whatsoever. Any thoughts
Could be anything from loose flywheel, broken magnet on flywheel, loose ignition module, to blown head gasket.
