Part numbers needed....
giovanni1
the model numbers I have are slightly different. I dont have the 'K' and I dont see the HX'C' anywhere listed. Is that because I am in Canada? or will the others fit as well?
HRC2163HXC
MAKA 1143900
76266-VK6-000ZA​
This one is listed under the HX'A' . I am assuming that is America? But will work with mine? (that is the mulch plug number) Slightly different than your number provided
Yep.Most of what you can get on the web will be USA only .
Dealers can of curse get all of the international numbers.
So you need to do things like substitute the America A for you Canada C .
The K gets deleted from some numbers as it only stands for a revision so K2 & 2 ( in the same position ) have the same meaning .
Stens have a decoding section in the references on their web page & I have posted the Honda one a few times but it is not on this computer but it is on the forum if you search "Honda Codes" you should find it
giovanni1
So the number I found is slightly different than the one you had posted for the plug
76266-VK6-000ZA vs your 76266-via-000za​
what is the 'vk6' vs 'via' difference? just want to make sure...
DOB
That model doesn't have a mulch plug
JBplays
It does have a mulch plug. The mower is a HRC-216HXA K3. It's just the Canadian version, instead of the US version.
giovanni1
I may have had some luck. The local Honda dealer says he has found one and is going to ship it to the dealership. Hopefully it fits!
76266-VK6-000ZA I was told is the correct part #​
Now if I can track down a bag I will be happy. He gave me a price for the bag ($38CAD) but by the time you add the frame and the whole bag assembly I am not sure it is worth it. Would not mind tracking down a used one in any condition.
vonrick33
Honda 76266-VG4-020ZA Stuffing Mulch Plug NH105--21.99-- Amazon has it in limited supply.
giovanni1
Just an update... the plug came in today at the dealer and just wanted to say that it fits the machine just fine. Thanks to all. Hopefully, I can find a used grass bag somewhere for it.
