corvairbob
- May 23, 2013
- 31
- 130
ok it seems i have spots from the dogs peeing in the yard. is there a grass that is tolerant to this? if so what type and can t be spread over the existing lawn or will ihave to till the lawn under and start over? it is pointless to just reseed the spots because as soon as i do they will just find another spot. they do not have a favorite spot but they do have a favorite area. plus one female seems to like to over pee on the other females spot so then i get a double wammy in that spot every time they do there thing.
i did some internet research and it seems that scotts turf builder grass seed tall fescue mix is on choice. unless there is a better seed that will work with a low maintenance.
i cut the grass at the 3 to 4" setting on the rider. and i do not water every day or even every other day my system i set to tuesday and friday for a 60 min watering at 10 pm the lawn does not seem any worse for wear with that system.
anyway can i get some seed and spread it out now in the fall and have it grow over winter in muskegon mi and expect to see the new grass in the spring? or should i wait until spring and sped what ever seed might do the job of glowing without having to till it in.
