grumpygrizzly
- Apr 4, 2014
- 18
- 102
OK, so a guy called me and told me he had an MTD 3hp edger that he wanted me to pick up for free. He wasn't at the house but left it out front. There was a bag tied to the handlebars. Inside were all the little connection parts for the outside of the carb..
The model number on the Edger Trimmer sticker reads 6059..
After cleaning a half in of gunk off the deck of the edger, I found the model number.
248-604-013. Looks like it was made in 1988.
Apparently he tried to fix it himself, got in too deep and gave up.
I've gone through the carb and done a thorough cleaning and now I'm trying to figure out how the throttle and governor controls hook up to the outside.
There are basically two parts that are giving me the fits. I've attached pictures of the two parts below. There's a spot up near the air intake on the carb that is where the throttle cable goes I'm pretty sure and one of the parts is screwed in that spot to hold the outside of the cable secure. There's a second hole down and to the right of that hole. These are the only two holes that have threads for the two screw that go in them.
If anyone can point me in the right direction or take a picture of one of these setups without the air cleaner in the way, I'd definitely appreciate it. I've already spent a couple of hours on this unit just so it doesn't beat me. I don't like losing battles like this. I've got an engineering mind and can usually figure these things out.
This one has me stuck..
Any help is greatly appreciated.
