does anyone have a diagram that shows how to connect the carb to the engine?
M mfrick Member Joined Mar 16, 2013 Threads 8 Messages 23 Jun 2, 2014 / old Tecumseh tc II tiller model number 161lc-n #1 does anyone have a diagram that shows how to connect the carb to the engine?
AnthemBassMan Well-Known Member Joined Apr 26, 2014 Threads 2 Messages 199 Jun 2, 2014 / old Tecumseh tc II tiller model number 161lc-n #2 You'll need the engine model # from the shroud. Probably above the spark it.
M mfrick Member Joined Mar 16, 2013 Threads 8 Messages 23 Jun 2, 2014 / old Tecumseh tc II tiller model number 161lc-n #3 The model number on the engine is 161LC-N. It also has a SEQ # 548N
Fish Lawn Pro Joined Aug 2, 2013 Threads 11 Messages 5,131 Jun 2, 2014 / old Tecumseh tc II tiller model number 161lc-n #4 the throttle setup you will likely have to improvise on a bit.
M mfrick Member Joined Mar 16, 2013 Threads 8 Messages 23 Jun 4, 2014 / old Tecumseh tc II tiller model number 161lc-n #5 Fish said: the throttle setup you will likely have to improvise on a bit. Click to expand... Did I get all of your reply?.
