Hi,
I have a Snapper 21357B Self Propelled walk behind mower that has a few issues:
1) Leaky gas tank. Gas tank is molded into the engine cover and leaking at a seam. I'm having no luck finding a replacement online. Any help to repair or replace this would be appreciated.
2) Air flap in carb not closing when throttle is pushed up to "choke". I have to take the air cleaner off and manually close it. Not a huge deal, but I will be giving the mower to a friend until she can sell her house, and I don't want to drive over to her house to start the mower whenever the lawn need to be mowed.
3) Rubber ring for self propelled mechanism needs replacement. Any idea where to get a replacement? Is there a place online for parts diagrams and part numbers. Any idea what engine came with this mower -- I think it's a Briggs, but can't find a part number and all decals are long gone.
Other than that, the mower runs great, especially since it sat outside for a couple of years. New plug, cleaned carb and it fired up on the third pull.
It stalled out a few times -- probably due to gunk in the gas tank -- but I installed a fuel filter where there was none before, and it will run all day -- or at least until the gas leaks out.
Tom
Tom
