Thank you again to all of you who helped me through my no-start problem that was finally solved as a bad fuel solenoid. Briggs 350777 Vanguard 18hp. Runs strong, but a LOT of oil running out of the air cleaner. So much that it is dripping on the exhaust. I'm frustrated because I just put all that time in tracking down the fuel problem. New breather tube, valves adjusted properly, clean oil at proper level. How would you attack this? 625 hours. It is in a Simplicity Broadmoor 1693600.
