Hi all,
I am new to this forum, so please correct me if I make mistakes.
I have an old B&S 93508 lawnmower motor from '82. It hasn't been used some time and didn't work anymore, so I decided to rebuild it.
Now I tried getting off the oil pan, but couldn't get it off. It will come off like 2cm, but not any further. It's just enough to put my fingers in between.
Put it back to the original position and sanded the shaft very well. It still won't come any further. All bolts are removed (obviously) and only the oil drain plug is still in, because it's stuck(but that shouldn't effect the disassembly, should it?).
Any tips on getting the oil pan off are highly appreciated.
Thank you,
Casper
Thank you,
Casper
