GearHead36
- Apr 26, 2023
- 7
- 90
A cautionary tale about oil filters.
I bought a used mower a little over a year ago. The engine had oil leaks at the valve covers. I fixed that and a few other things. Got it back together, changed the oil & oil filter, and used it last season. About an hour & 45 minutes per week. At the beginning of the season, it ran great, cut great, and no leaks. At about the 2/3 point in the season, it started using oil. I thought. Then, close to the end of the season, I noticed that it was actually leaking oil. Luckily, I check the oil before every use, so I just topped it off every time. After the end of the season, I realized that it leaked even sitting parked. The mower is a commercial Cub Cadet with a Kohler EZT750 engine. I like the mower. It does a good job, but engine access could be better, and the engine weighs about 100lbs. I'm over 60 with a bad back, so there's no way I'm able to just lift the engine out of the engine bay. Pulling the engine solo is something of a job, so I decided to wait until after the end of the season, and do it when I did my annual maintenance. I pulled the engine, and found the oil leak. It was the oil filter, which was also Kohler. It had loosened. I had tightened it up just like I do automotive oil filters (snugged by hand), and those get tighter by the next oil change. I've never had an automotive oil filter loosen up on me in about 45 yrs of changing oil. This one loosened, and made a mess. It could have destroyed my engine. So now I'll be checking my oil level AND my oil filter before every use.
This was the 2nd time I pulled the engine, and I AM getting faster at it. If I need to pull it this coming season, I won't wait till the end of the season.
