graydog
- Mar 16, 2012
- 8
- 70
I have had my 60" Great Dane ZTR W/25hp Kawasaki for several years. About the only complaint I have had is they put the oil drain valve on the left side, behind the battery. That engine has a tap for the drain on both sides, so I bought an oil drain line made for the Exmark W/25hp Kawasaki and installed it on the right side of the engine. It is Exmark Engine Hose Oil Drain ASM [W] , Part # 116-4924. It is a high pressure steel reinforced line made especially for the Kawasaki. It has a male thread and O ring to fit into the engine and a drain plug in the other end. Do not attempt to use anything else, such as pipe threads. Changing oil is a breeze now.
That part can be bought online here: http://www.partstree.com/parts/lc=exmark&mn=TTX24KAECA+S/N+920,000+&+Up&dn=51_03_0007
