humphrey1989
- May 1, 2014
- 7
- 28
Surging idle - to much air suspect
I have a Craftsman High wheel weed trimmer model #917773703 (Briggs engine)
Was sitting around for a while so I cleaned the carb, put it back on and it wouldn't start. Used a sprayer with gas to start an sustain it.
Gas lines are fine and free flow gas to the carb, not very much coming out the check on the bowl. Pulled off the bowl, float is free, little gas, not much.
Bought kit for it: Kit-Carb Overhaul [498260] - $10.16 at eReplacementParts.com
Installed today, still will not start, gas flow issue. Installed new needle and seat and seals all around. Kit came with more stuff but doesn't look like it all goes on this carb.
Started and sustained with sprayer but will die if I stop.
Not sure what to do now, any ideas?
Exploded carb diagram: http://c.searspartsdirect.com/lis_png/PLDM/P0301218-00002.png
~ED~
So I went out and messed with it again, now it works
Turns out I hadn't pressed the needle seat all that way down..
~ED~
