Hey guys, I am not experienced at fixing small engines, in fact I bought this lawnmower which is about 12 years old just to play around with.
It was working before I got to it, now... not so much now...So here is the issue. I completely disassembled it to clean off carbon, change piston rings and gaskets. I watched enough videos on youtube to learn about how to disassemble and reassemble it. So after I cleaned it off and reassemble it I couldn't get to start. I ruled other possible problems, so the only thing that is wrong with it is no compression. I connected my compressor through the spark-plug to test where is the airleak and it turned out that the exhaust valve does not hold the seal, so as the piston rings. So I took the piston out to make sure that the rings are placed in a correct order and in a correct way and I made sure that ring openings are evenly spaced apart. The exhaust valve is the original valve I just cleaned it off carbon.
I am not sure what went wrong and why there is now compression. Is it because I used carburetor dip to clean off valves and rest of the engine from the carbon build up? Please help.
