I have a 2009 Cub Cadet M72 Tank and I'm not getting any charge to the battery. I have checked the output at the voltage regulator and the most I get from either terminal is about 10.5 Vdc.
I should be getting above 26 volts, or better, if I remember right. I have removed the flywheel and cleaned around the stator but that didn't help.
The engine is a Kawasaki 37 HP two cylinder and the mower runs fine but after about 3 hours I don't dare turn it off unless I have a battery booster available. The battery is new this year and the cables are clean and tight.
I have checked across the battery terminals while the engine is running and all I get is 12.6v rather than the 14 volts I should be getting from the voltage regulator.
I replaced the voltage regulator and that didn't help. Do I need to change the stator and what tests can I run to check it?
Thanks, Mike
Thanks, Mike
