new needs help !!!!! john deere l 110 18 hp bs motor
4719dave
I got screwed by lawn mower shop ...so neighbor fixes and sell riding mowers .no gas in the bowl .blue out lines .cleaned tank ,replaced filter ....still nothing called neighbor ..he replaced fuel pump but still not pumping gas internal part broke ???
NEW GUY NEEDS HELP ...Cant fix thread title ..
In the case we need your help. Please supply us with the model type and code numbers for your engine. Also, provide us with a little more info, as to what the shop did and how it was returned to you.
TJR345
  • / new needs help !!!!! john deere l 110 18 hp bs motor
Could be air lock in the fuel system.Do you have fuel after the fuel pump.
DaveTN
Try bypassing the fuel pump temporarily with a shot of starter fluid or carb cleaner into the carb intake.
It should fire off and run for a few seconds. If it starts and runs then as you indicated you have a fuel
starvation problem. Try using a temporary gas tank and line with gravity feed and see what it does. If
it runs then it would probably be the fuel pump either not getting sufficient vacuum or perhaps something
internal with the diaphragm causing it not to pump fuel.
reynoldston
Had a customer with same problem. He hooked up the fuel pump hoses wrong.
RjMaan
Oh that is really a serious issue. I think you should ask a mechanic to check it or you can also keep the latest John Deere 110 Service Manual which will help you in the repairing of your lawn mower.
