junkfixr
- Aug 16, 2011
- 5
- 13
Thanks for having me here first off. I've been to the end of the internet and back a couple of times trying to figure this one out and am happy to find this site.
2006 Craftsman LT1000, and the sticker under the hood sez i need 144959(1/2 x 95 1/2) deck belt. Picked one up at the local parts store and it's WAY too tight. So i search and find there's a 5/8 x 97 also used on 42" decks. Not the belt ! So I search some more and find there's a 1/2 x 100 1/2 inch belt. WAY too long.
I'm kinda at wits end as I've done every adjustment to try to get enough slack so that my blades don't stay engaged. It looks like I need a 1/2 x 98 belt to get enough slack to engage the blades normally. Could the sticker under the hood be incorrect, or do you think I've got something else going on ? It's not the routing because I can put the original (worn out & slipping) belt back on and it engages and disengages perfectly. The 144959 matches it closely in length , just not enough slack when installed.
I've searched model and serial #'s and done the Sears Parts Direct thing, but keep coming up with 144959 which seems to be about 2+ inches too short.
Thanx in advance for any help or suggestions.
Kevin
Kevin
