New guy with beginner questions. Is there a oil drain plug or do i need to tip mower to drain ( Husqvarna awd self propelled walk behind )
scm_UsedOwner
  • / New guy with beginner questions. Is there a oil drain plug or do i need to tip mower to drain ( Husqvarna awd self propelled walk behind )
Title contains my question. Thank you.
Koehler engine model - L 321AH
Bertrrr
I've seen both a drain plug and having to tip the mower over, if there's a plug it will be on the base or underneath the machine , doesn't hold much so it's pretty easy.
Husqvarna L321AH with Kohler HD775 engine.
Or if you are a repair shop use a pneumatic oil extractor which is much cleaner to use and less of a hassle.
scm_UsedOwner
Many thanks guys
Joed756
For $10 or less you can get transfer/siphon pumps powered by hand or by your drill and make oil changes easier and less messy.
scm_UsedOwner
Thanks Joed. That sounds like the best answer.
Would you happen to have a link ?
Joed756
