New deck
twall
I have a four-stroke, self-propelled (belt driven) Lawn Boy. I really like it, and it cuts well. But, the deck is shot - and it needs a re-ring job.
I have seen several decks on ebay (mine is the steel deck). But, the ones that are the naked deck don't seem to have accomodations for the self-propelled feature. How hard is it to modify it to make it work (with torches, grinders, etc.)? Or will that weaken the deck? Is it a special deck unto itself?
Will a two-stroke deck work with a four-stroke engine?
Also - how close is Kawasaki green to Lawn Boy green? on my mower, they seem the same.........
Thanks in advance.....:smile:
twall
Steel deck, 4.5 HP, model# 10302, serial# 6910703
Lawn-Boy Dealers and mass merchant retail outlets, including Sears, Lowe's and the Home Depot, sold these mowers from January 1997 through November 1998 for between $280 and $400.
hankthecrank
As far as modifying a deck that it up to you and your mechanical abilities and tool access, as far as the 2 cycle deck if the right one is found it will work, use this link and then enter the model number you have then you can do a cross refernce to see what will work for you, https://lookup3.toro.com/partdex/index.cfm?xCaller=LawnBoy. As far as color that is up to you and your eyes, but the closest match out there as far as a rattle can in Grabber Green, that is available from several different manufacturers.
twall
Just bought a 10301 'silver series' (which mine is, too) deck (the two-stroke version of mine, but the 4-stroke mounting holes are there, too) on ebay. She'll be going by the summer! Thanks for the help. :thumbsup:
Can't seem to find the Grabber Green you're talking about. Is it Rustoleum? Krylon? Generic?
Thanks again.
hankthecrank
twall
10302 pics
HTC - I just ordered 2 cans of what you suggested. Hope it's right........
Here's the 'before' pics:
