Need Trickle Charger
warb
Any Suggestions for a Good Trickle Charger ? Thanks. I bought Battery in the Spring. After a week of not starting Mower, battery
turns engine over Slow then finally speeds up. After 2 weeks it sounded "Dead", but finally worked an hour later.
I would think is more like a bad connection or a failing starter. Batteries don't magically recharge themselves other may developing a surface charge.
I got a Kohler V-twin in the shop right that is acting that way and it is a bad starter.
warb
Good Ideas. Thanks for Replies.
