lostinbaja
- Aug 8, 2012
- 10
- 37
I recently purchased a Woods "Mow N Machine 2855" it has a 2 cylinder opposed Kohler engine and it looks as if that size and brand of mower all cam with Kohler Magnum M18 engines.
My problem is that the sticker that contains the Serial number and Model number of the engine is worn so badly, I can't read any numbers and the local shop won't look up any parts without the numbers. Does Kohler stamp numbers into the block anywhere?
Any help would be appreciated.
Jerry...
Jerry...
