I have a TCII with under 100 hours (bought new) and in the past couple weeks it has developed the following issue. Initial startup is fine, but after cutting for an hour or so, if I turn the mower off for any reason it will not restart. Gas is full, oil is good, all safeties are in place (sticks, e-brake, seat).........so I am at a loss here. Battery has a full charge too. It won't even crank, just turn the key and nothing. I assume it has to be some electrical gremlin because mechanical failures usually do not come and go. As I said, when it starts it runs great, zero issues.
I tried Google (which is ultimately how I got here) and it seems like the TCII and TTII have issues with the relays and/or fuses, is this true? Any way I can narrow down what to check before going through the entire wiring harness? Are their common relays or switches that tend to fail?
EDIT.......it's a 61" with 23hp Kawasaki 730FX engine.
Any help is appreciated, thanks in advance.
--Joe
--Joe
