Pauls_Workshop
- May 28, 2014
- 1
- 5
Hi, I'm new here and need some advice. I have a Troy Bilt TB20CS trimmer weedwhacker that had the pull starter cord broken. I managed to get it apart and got the clutch cover off and pulled out the recoil spring assy to put in a new cord. I'm stumped on how to rewind the cord and the spring and then get it back together with the cord properly wound.
I can turn the spring assy and it will pull the tied cord in with it and rewind, but I can't then get it back in place and mounted without it just uncoiling. There seems to be no way to do it from outside it's plastic housing once it is installed and the clutch put back on. I tried turning over the whole crank via a wrench on the clutch and that will also wind the spring, but again once you let go it just unwinds again. I tried this again and torqued the T20 screw that holds the clutch cover bell over the clutch to try to hold it in place and just broke off the T20 screw in the process. Please help with the best procedure on how to do this right. I'm stumped and surely doing this all wrong. I'm buying a new clutch cover with screw to get back where I was for $15 but need help here! thanks! - Paul
