My ZD326P wont shut off!
rmd1960
Nothing i do will shut off the engine! I have to turn off the fuel and starve it to kill it. What shuts off these diesel engines?
Justlawns
Cut off the air flow or you might have a bad key switch
zd326s
my zd 326s has a fuel shut off lever(manual shut off) directly below(on same shaft)as the throttle linkage.just take your finger and push lever toward rear of lawnmower and hold till engine shuts off.
hope this helps you,let me know.:thumbsup:
tyjoja
my diesel lawn mower has an electric solenoid that shuts off fuel and kills engine. My solenoid went bad and would not lever the fuel shut off. previous owner by passed with a cable thru fire wall
midnite rider
I guess thats why they call it dieseling. :laughing::laughing:
The key.
Eliminate the airflow or fuelflow as you are doing to the motor and it will not run.
