HI all,
Glad I found this forum, looking forward to a little help. I have an older Murray 309029x92B that runs well and has been relatively trouble free. Yesterday (halfway through my lawn - naturally) the mower started squealing like crazy and the blade stopped turning. The splined shaft connecting the input pulley to the blade was hot... very hot... like take-off-your-fingertprints hot!. I really don't want to talk about how I know that!
Anyway, the input pully/shaft assembly didn't rotate ... until it cooled off... then it was fine for a minute & then seized up again. Seems to be the the Mandrel Housing (or Jackstaff Assembly - depending on your source). I am trying to verify that there is some kind of bearing - roller bearings - ball bearing in that part (#94305) that would seize up. Also open to any comments or advice!
Thanks to all
Mike
Thanks to all
Mike
