Mulching blades have more lift as well. If you live where the yards are sandy, using mulching blades will wear you deck out a lot sooner with all the sand they pick up. They also slow the rpm of the blade tip because they create more drag with having the higher lift blade.
I have gone to a low lift blade and after trying them I will use nothing else where I live.
