I acquired a Mastercraft 137D673G515 garden tractor (made by MTD) that needs repair. It was sold by Canadian Tire in Canada and the MTD data base won't accept the serial number in order for me to download a manual for it. Does anyone have a valid MTD serial number I could use? Also, it needs a battery... would a "200 cranking amp/165 cold cranking amp" battery be adequate. The tractor has a 15.5 HP B&S engine with electric start. It's only accessory is the 42" deck. Thanks for any advice/help.
