MS290 Chain Tensioner Replacement?
GSPKurt
The tensioner pin that fits into the bar on my MS290 has disappeared. How do I replace the tensioner assembly? Thanks.
Yep.
When installed it can't go anywhere because it is held in by the chain bar.
Usually there will be a bridge across the tensioner mechanism that stops it falling out.
These saws are a bit new for me the stuff I get in is generally 20 years old.
GSPKurt
Yep.
Thank you very much! :thumbsup:
