Mower stuttering and black smoke.
Mechphisto
Hi, we've a mower giving us problems and wondering if we could get some advice.
It's an 8 year old 22" Murray push mower with a 4 HP Briggs & Straton engine. I admit, we haven't maintenanced it as well as we should. Although, I always check the oil (SAE 30) and never leave old gas in it.
It ran perfectly fine until last week without warning it started sputtering and losing power, going rrrr-RRRR-rrrr-rrrr-rrrr-RRRR... and sputtering black smoke.
It has no problem starting, it starts right up.
Also, like 30 seconds before it runs out of gas it'll suddenly start working fine and the engine runs nice and normally.
We replaced the air filter (the spongy kind... I know you're supposed to be able to wash them out, but it was pretty bad. Thought it best just to replace it.)
Any ideas of what I can do?
Thanks!
if that is the engine with the carb mounted on top of the fuel tank, you need a new diaphragm between the carb and the tank. the carbs tend to warp on the engine side of the carb and the diaphragm pulls out and then sucks fuel around the edge and makes it run rich.
Mechphisto
Thanks for the reply!
Unfortunately, I'm not engine part knowledgeable. All I can tell you is the fuel tank sits immediately below the primer button which is immediately below the air filter. And then the exhaust is on the opposite side of the motor.
If what you say is the likely cause, is that something that's easily self-serviced? I'm not engine knowledgeable or experienced, but I follow instructions real well. :)
I'm just afraid taking the mower to a qualified service person will cost more than the mower itself did.
Thanks for the feedback!
KennyV
Welcome to the LMF...
Well here is a young fellow doing exactly what you need to do, easy to DIY...
He has not the most sanitary working conditions ... but hey, he gets it done...
this guy is doing it mostly with one hand (he is holding the camera) while doing it...
Watch this and you will see its not a big job... YouTube - How To Replace The Diaphragm On Briggs And Stratton Primer Plastic Carburators On Metal Gas Tanks
:smile:KennyV
Two-Stroke
:smile:KennyV
That's an impressive video -- not that the job is all that hard but shooting the video with his left and doing the repair with his right.:cool:
Mechphisto
... KennyV
Thanks!
And thanks for the link! That looks just like my mower. And it looks like I can totally handle the job. :) I think the hardest part is emptying the gas tank without wasting any! (That stuff's liquid gold right now.)
Now I need to find a place that sells the diaphragms...
Thanks again! :)
KennyV
Sure is ... one handed repair, shows how easy the job can be.:tongue:..
Post back with how well it worked ... Looked like he bought his at 'True Value' hardware for just under $5....
:smile:KennyV
PS... since this will be your first diaphragm repair .. use both hands... :biggrin:
deltabox888
My briggs and stratton was doing the same thing. I would be able to start it then start to rev up and down, up and down and then finally just die out.
Find the air intake valve. It would be behind the air filter. Start the mower and then play with the valve. It could be stuck in the wide open position. Try to close it and see what happens.
