I have a riding John Deere mower with 42" cut. Just changed the blades out. Now when I engage the mower, it dies. Does anyone know what may be causing this problem?
If you try to engage the brakes without being in the seat or get off the mower with the blade spinning the mower turns off.
So there is a 99% chance the seat switch is crook or the wire hat goes from the seat swtich to the prop switch is broken, loose or shorting.
