Mower deck Mower deck ajustment
AndrewWisner
I have recently purchased a Dixie chopper silver eagle 2760kw and the mower deck on it needs to be re-aligned from side to side. On the left side of the mower deck i can stick my hand under the deck wheel with the deck all the way down. on the right side i cant put anything under the deck wheel. Would be nice for some feedback ASAP. Thanks,James.
The Don'z
Try cutting 4 blocks of wood, set the deck on the blocks (on a level surface) set your deck adjustment and adjust the leveling bolts as necessary. Hope this helps.
BlazNT
check air pressure in tires before you start anything
