Magneto ground wire
navydad2022
I disconnected the magneto ground wire and my mower started,l have a snapper riding mower and was trying to figure out what the problem is.once l connect wire back and it won't start.
navydad2022
Could it be a ignition switch or safety switch.
Yes
the ground wire is open circuit to run & closed circuit to stop
So you have to trace the wire back to find the faulty switch or short to ground
I find it easiest to clamp one lead of a test lamp to the battery + then probe to find a ground which of course illuminates the test lamp
navydad2022
Yes
navydad2022
Thank you,I started by the magneto to check for spark,The ground wire attaches to a central location on side of engine and from there to solenoid.
navydad2022
I'm a newbie on riding mowers, should I check ignition switch and safety switches,it starts fine when disconnect wire on magneto
Yes along the wiring especially if the kill wire run behind the starter as that is one place they get pinch when someone replaces the starter and don't pay attention to the wires.
navydad2022
Hello Star Tech and Thank you for everything, did a little finessing on the Snapper 281223BVE.now the mower doesn't crank, check the ignition switch and the solenoid and this what l have going on.I have 12.89 voltage at solenoid connection and also at the starter connection.could the switch and solenoid be bad.
navydad2022
Also checked the wire at the magneto connection no cuts.
