magneto coil
swinks
lx176 mower stopped working, had fuel but no spark. Changed out the magneto coil with a new one still no spark. Tested the coil with a ohm meter and tested ok, still no spark. Week magnet????
pugaltitude
Start off with easy things first.
How you checking spark?
You need a spark tester. A spark tester checks
usually it is safety switches on seat, neutral position, brake or pto engagement.
Check these circuits and you might find the problem.
