Hi all,
I recently purchased a mzt 61. I have put just 3 hours on so far but have enjoyed using it. I do have a question about the hydro reservoir. Upon getting the mower I check and the reservoir appeared low so I added 20w-50 up to what I thought was the cold fill level. Now after have used the mower I appear to have "sprung a leak". Is the small diameter rubber tube coming out the top tank an overflow? Whats the roughly 1/2 inch diameter 1 inch long thing attached to the end of that rubber tube?
Thanks!
Thanks!
