LX188 stopped running
Cruiser 7
My LX 188 just stopped running "when" I was mowing, plenty of gas, Battery fully charged, oil was recently changed, cheched the fuses at the ignition board. I turn the key, nothing happens, no dash light,no sounds at all. My head lights work, hour clock is working. I have not manually tried to turn the motor yet (to check if it sieze up). I also checked the seat safety switch seem to be fine. Would love any help, Thank you
Stopped how ?
like you turned it off
or
like it ran out of gas ( pulsated a few times )
Also the engine make & model helps
hsherm
I've never worked on one of these, but it sounds like either the safety switch isn't making a good connection, even though it may appear to be plugged in all the way, or you have a loose ground wire. We had problems on our mower with the safety switch not making a good connection but it still looked connected. The wire was cut too short by the manufacturer. So I added app. 3" to the wire and it solved the problem.
