Lubing pedal pivot points
gimmodog
the best penetrating oil is definitely Aero Kroil. It is very expensive and stinks bad but it works great. Is also a little hard to find, most refrigeration supply stores carry it or you can order it online
Stan
JDgreen
Stan
Never heard of it, I have a can of penetrating oil that is close to 15 years old now, I have always thought anything would basically work. A lot of people don't bother to tap things after squirting the oil on, the vibration helps work the stuff in.
gimmodog
You get a can of Aero kroil and try that and you'll never use anything else, believe me it puts all the others to shame.
Stan
reddragon
yep....propane torch and a bowl of ice coubes or super cold water.....a little tapping goes a long way:thumbsup:
Black Bart
THAT BRINGS ME TO ANOTHER QUESTION......WHATS THE BEST PENETRATING OIL??
BLASTER
To lub pivot points I like aerosol can of motorcycle chain oil it comes out thin designed to run into a chain but a short time later it turns into a grease and stays in their.
reddragon
that motorcycle lube is great!...i use it when my little squirt bottle cant get in there:thumbsup:....i dig blaster!....glad to here you guys like it too!............ill have to try that aero stuff
gimmodog
This is what the Aero Kroil can looks like. 2 different sized cans.
reddragon
ive seen that before in the parts place!...ill try it out:thumbsup:
benski
+2 on Aero Kroil.:biggrin: It smells like sin, but works very well. I have also had good luck with PB Blaster. Some heat, some smacking, and some patience will usually get stuff to let loose. Otherwise, an impact gun, a nut splitter, a cutting torch, or a grinder are my tools of the trade.:ashamed::wink::smile:
