Billy Goat F1302SPH Blower
$2,049.99
The Force II produces the highest static pressure of any wheeled blower available. Period. A distinct black grill marks the Force II. Unlike metal housings, the proven housing features a smooth, rounded design that eliminates air voids, reduces noise and increases output efficiency. At 16 blades, Billy Goat has 2x as many blades as the competition.
Little Wonder LB170S Push Blower 9170-03-01
$899.99
The Little Wonder Optimax Push LB170S is powered by a 170cc Subaru SP170 engine. Built with a fully-welded steel housing for extreme durability and 10” Rear, 10” Front tubed tires for less maintenance. The 7-blade, reverse angle, impeller is dual plane balanced, 17” steel with integrated pull ring. The discharge chute is 14.8 sq. in.
[h=2]
Brown Stand-On Zero-Turn Blower BVZ4000H[/h] Regular Price: $8,999.95
Special Price: $7,599.95
The BVZ4000H Stand-On Blower-Vac boasts a powerful
Honda GX690 Engine, moves at up to 8 mph with it's reliable ZT-3100 Hyrdo-Gear Transmission. With Zero-Turn radius movement and 20" x10" Tires, you can handle most terrains.
