Log Splitter part 2
Rickhise
Recently replaced a engine on my splitter
The new 6hp B&S
18 0306 58 76693
If I need to replace this engine for reason
Described in my previous log splitter post
(Horrible kick back on pull rope)
Beside hp an vertical shaft what else should be
a priority for the type engine for this job
I just replied to your other post about the number you posted is the serial number and not the actual model number of the engine. I suspect that the new engine has an aluminum flywheel which is used on push mowers, whereas you need the heavy cast flywheel like what is used on pressure washers and other applications that don't have a blade.
