Lesco 48" walk behind
Donniekey
Thank you kindly in advance for any help you might offer.
I've purchased a used Lesco walk behind 48" mower but the 17 HP motor was replaced with a 24 HP Kohler, problem is that there is no pulley on the Kohler motor and the previous owner didn't have the original pulley that was on the 17 hp Kawasaki motor that maybe was a double pulley that goes on the motor shaft and drives the transmission and also the deck. So I'm think it has to be a double pulley maybe but I have no idea as to what diameter either of the pulleys are or if they are both the same size or anything, I'm just list. Please can anyone help me? Again thank you kindly if you can offer any info.
