Export thread
Left steering arm stiff. Any help appreciated
#1
D
Doug67301
My 1995 718K 52'' left steering arm gets hard to push forward at times. Half the time it moves normally. Reverse action, works normally. Changed the hydro reservoir oil and filter. No help! Tried adjusting the forward reverse linkage but no help. I returned adjustment back to original setting. Anyone else have this problem?[/B]
#2
BlazNT
BlazNT
I would check all the joints in the system for corrosion, Then check your dampeners.
Read this post
http://www.lawnmowerforum.com/showthread.php/10058-616-with-stiff-steering-arms
#3
173abn
173abn
on my older 928d there is a grease zerk.not sure if yours has one but if it does might just need a little grease..russ
#4
B
The arm has zero resistance, it just opens & closes a valve that is why there is a damper on there
#5
D
Doug67301
I will check out these recommendations, thanks for your input.
