Hello
My steering arms on mower are stiff and wont return to neutral on their own. I have searched for a grease zert but unable to find any. The manual that I have doesn't cover much and it doesn't cover any lube points.
There are really only 3 places that would cause restriction that I can find. first one being right where arm pivots and rotates when you are in the drive position the next one looks like there is a bushing where the linkage connect going to hydro unit and the 3rd being the point in which the spring loaded center return point for the neutral. I have sprayed lube but I am sure that the dust and dirt will only cause more trouble.
any thoughts or suggestions?
Thanks
Bob
Thanks
Bob
