The float valve is leaking. You will need to remove the carb, clean and install a carb kit. this model most likely has the rubber valve seat that will need to be replaced. Just don't get any spray carb cleaner around the new seat because it will swell and then crumble.
Thanks very much for that info. !!!!!!, i will give it a try, i'm no gear head but i will get a kit and give it a try, doesn't work as it is , 'nothin to lose .
wellllll, i tried, not a lot on this simple carb to do. I changed the needle, the seat, etc. blew out and cleaned, re-did with new parts........ put back together.....still gas runs out freely out of the primer bulb............ at a loss.
thought i did good, but....... apparently NOT
any more ideas ? it can't be this hard.......?????
