Lawnboy model 10525 Gold Series 6.5 HP Grass Catcher Bag
intruder1500
  • / Lawnboy model 10525 Gold Series 6.5 HP Grass Catcher Bag
Anyone know the OE part number for the subject side mount grass catcher bag. Looking to find an original part if possible.
Try Lawn Boy #89816.
intruder1500
Close but mine has no handle. There is just a cloth strap that hangs on the wire frame mounted to the handlebars and the chute has no handle....just a rectangular wire frame built into the end with a slot that the chute clip mounts to.
Try part numbers 89800 or 89801. Only three bags which came with that model number, depending on serial number.
intruder1500
I found a pic of the bag on My Tractor Forum ....the rod for the bag is not the same..... mine mounts to the side handlebar but the bag appears to be identical.
My 2 10525's are as follows:
10525 MINE8903456
10525 NEW ONE9902098
10525 PARTS MOWER8903443
I did not have any luck matching 89800 or 89801 to my part.
PS - I just found part #89816 on the Lawnboy Website for this mower but there is no picture to verify. It looks like Lawnboy changed the bag and added an adapter to the chute housing with new separate part numbers and it requires a different chute......
intruder1500
That’s the number I listed in post #2. Just type the number into your search engine and you should find a picture and source.
intruder1500
Unfortunately every site I go to shows a pic of the 89816 upgraded bag with the 3 holed handle and different attachment to the chute.
Post a picture of your old bag.
