SGRIFF144
- Feb 23, 2014
- 6
- 19
Recently I purchased a carb rebuild kit and replaced all of the gaskets, welch plugs, and needle. The mower has spark and will run on starter fluid until the starter fluid is used up. Gas flows into the carburetor bowl. Gas flows with the float in the down position and ceases when the float is elevated. ( I believe this is correct) I am wondering what the next step in carburetor troubleshooting should be. Thanks for the help.
Sean
Sean
